I bought a couple of full width hubs for not very much at Netley, Iâm using the best one for a special Iâm building, the hubs have brake plates but not bearings, spacers or stub axle. Thatâs all available from Andover etc, but the bits are not cheap! Iâm thinking of dumping the stub axle and running with a single full length axle ( pre featherbed swinging arm frame). Has anyone done it before? It looks easy enough to make up some spacers.
dan
hello dan the only way is…
Hi Dan, I think you should…
Hi Dan, I think you should be able to do that although obviously you will lose the QD facility.
A related topic: I recently decided to investigate (not before time!) an apparent ovality in my rear brake drum ('56 19S, full width hub). I fitted a new drum/sprocket but with little improvement. I went back to the original drum and marked the hub with the 3 possible orientations wrt the drum. Fitted the drum in position 1 and measured the run-out, then repeated for for positions 2 & 3. In the best position I obtained an acceptable run-out of around 0.005". In the worst position it was nearer 0.018". Hub and drum are now marked so it will always go back in that orientation. I assume that there are small manufacturing errors in both components which almost cancel out in one position but add in the other 2 positions. The best result with the new drum/sprocket was again around 0.005", the worst was better than the old one at about 0.012". Maybe this is well known but it took me the best part of 40 years to find it! If you think your drum is out of round try repositioning it on the hub. You may not need a new drum after all.
Ian McD
hello dan the only way is to experiment and find out your own way mate its all in the learning curve even at 64, I have never stopped learning something new never shut off your mind to new things and do experiment with your own new ideas you never know you may end up being a millionaire one day good luck and happy hunting yours anna j
