Hi guys
I'm on the scrounge. I need to borrow a plug type 1/2" 26tpi tap for a short while to tap a new hole for the prv inside the timing cover. No point in buying one as I'll likely never use it again. An engineering firm is building up the boss but does not have a suitable tap as apparently it is very unusual.
Would greatly appreciate any help.
George
Stand down guys, someone h…
Hi George - Are you repair…
Hi George -
Are you repairing original or e bay purchase ? Just curious
Richard
The original, Richard. The…
The original, Richard. The ebay seller was very understanding and took his one back on a full refund.
The engineering firm intend to build up the prv boss with an ally weld then re-tap the thread.
George
Previously George Phillips…
George
hello well if I had been asked I could of set you one to keep as I have all types of taps and die nuts, and drills from the smallest needle drill one sixty fourth to the largest two and half inch drills made by cleveland drills and you need a flute tap to start with witch I have these as well Has I use them on My 1937 Atlas model F ten inch swing over bed Late now fitted with Cam and Cad three D programing from my lab top and variable speed control, not to forget my harrison mill drill ! keep up the good work george yours anna j
Previously anna jeannette…
George
Annathisissoundin likearun destination for theengineeingtypes. Any thoughts on that?
A littel gem thatsoundssimilar istheelectric railway workshopsin Douglas IoM. Lineshaftdrive andwheelrim press amongstthemany wierd andwonderfultoolsto keep thethings running. Justbeyond TheTerminuspubnorthendof Douglasbay. Andfor theVMCC members amongst you ... ...itsfree.
Wish I'd know that when I…
Wish I'd know that when I was there, Jonathan! I'd have got in free as well!!
George
Stand down guys, someone has come up trumps - as we say over here!
George
