I'm just putting the finishing touches to my '63 Norton 650SS restoration. I've applied the "Oil bath" water slide transfer to the primary chain case. Would there have been any other transfers or decals applied anywhere else on the bike and if so, are they available?
Thanks.
How about the Oil level…
Thank you, Howard I've had a…
Thank you, Howard
I've had a look on "Classic Transfers" and found the three shown in the attachments below. Are they the ones you refer to?
Number one and number 3 look…
Number one and number 3 look correct for 1963. The Roadholder fork transfer for the top shroud is for the wide yoke forks so your's would have had the brass badges held on br small round head screws. They are available. Similarly the patents badge for the crankcases are available. Cheers, howard
How about the Oil level transfer on the oil tank and the 650SS scroll on rear mudguard behind the seat ? The Roadholder transfers on the top fork shrouds may have replaced the badges on the earlier models...... There is also the oval patents badge in red on the drive-side crankcase above the primary chaincase. Good luck, Howard
