I’ve just spent a hour in the garage (freezing my fingers off!) looking for the number of the frame I was going to use with my navigator build, unfortunately there is no trace of a number anywhere around the rear footrest hangers. The engine and frame came together and were once a bike but I can’t be sure they left the factory together! As I have no registration details I don’t want the complication of obtaining a number from DVLA, that way lurks a Q number if you are not careful.
So has anyone got a standard navigator frame or rail with a number on it, pref pre 64 that they would like to sell or swap for a delux jubilee frame or standard (complete with centrestand) I don’t need the front header tube or the central section.
Cheers Dan
Hi, the number should be on the rear footrest bracket, mine is just under the weld. hope you find it. It should match the engine number if they belong together.
