Re conversion to 12 volt. Mines a deluxe model. Has anyone managed to fit a 12 volt battery into the existing battery tray behind the side panel. Ive had a quick look on line and they all seem to be a bit bigger than the tray. Would prefer to keep the tray.
John.
Yes. I have a 12v battery…
Mine fits perfectly! Altho…
Mine fits perfectly! Although itâs not a deluxe
Patrick, yes I know about…
Patrick, yes I know about the acid.
Cannot find a 12 volt battery that will fit the tray. Some of 12 volts are only a bit larger than the 6 volts. Should be able to alter the tray. Ive got about 15mm to the right side and above plus about 20mm in front
John.
Hi John, I have just measu…
Hi John,
I have just measured the battery tray on my 1959 Jubilee De Luxe and I make the measurements ;
Length 130mm, Width 70mm, Height 150mm.
The 12V YB3L-A measures;
Length 100mm, Width 55, Height 115mm.
Dan's battery measures - per the web site ;
Length 114mm, Width 70mm, Height 87mm.
So they all fit. The YB3L-A seems to be the identical size to a six volt Yuasa sitting here on my bench - normally fitted to the Navigator de Luxe.
I have just purchased last week a Motobatt MB12U for the 1959 Yamton and it seems a cracking good battery - the self starter really spins the engine easily. But that is a much bigger/more powerful battery which fits under the seat in a special battery tray.
Patrick
Patrick Is the deluxe batt…
Patrick
Is the deluxe battery smaller than the standard then?
dan
Hi Dan, I regularly swop b…
Hi Dan,
I regularly swop batteries of the YB3L-A size between the De Luxe and the Standard without any problems so I think the battery tray in each is actually very similar. At first glance I thought the Standard battery tray was smaller than the De Luxe.
Your Motobatt is fatter and lower and slightly longer than the traditional 6v or the YB3L-A but fits in either of them according to my measurements of an actual De Luxe tray. It looks a little fat in the Standard -presumably the lid does fit on?- so there is actually more space in the De Luxe for the fatter battery. (I measured three De Luxe trays -all were the same size)
Patrick
Hi Patrick, thanks, and ye…
Hi Patrick, thanks, and yes the lid fits on perfectly! I borrowed the motobatt from my son in lawâs aprilia 125 when I was first getting the Jubilee to run, it fitted so I bought one! I previously used one for my Gasgas 400which it spun over much faster than the exide it replaced and they require less maintenance in the winter.
Dan
The Motobatt looks the job…
John.
Yes. I have a 12v battery fitted in the tray. It is branded as an Aerco, Coventry, England and the code number is YB3L - A. It came from a trader at Rufforth auto jumble a good few years ago. It was purchased on the scientific principle - it was the smallest 12V battery and even more importantly it was the cheapest battery he had. It still manages to keep a charge. Actually the battery tray on the De Luxe holds a bigger battery than the tray in the toolbox on the Standard.
Did you know that there are new regulations in force about battery acid? Effectively now you must have a battery already filled with acid (or an AGM battery ) and you cannot legally be supplied with battery acid in a separate container.
Patrick
