Green varnish in fuel tank
Hello, cleaning up my old Navigator tank to prep for paint, the inside has a coating that looks like a green varnish, it is scratched so needs to be removed and replaced with some new gunge. Trouble is I have not come across a green tank sealant. It is a little brittle and has not given up much with the old nuts and bolts trick. Neither Acetone nor Celulose seems to touch it. Any ideas anyone?
Previously Steve Adkins wrote:
Try this product, note the devil in the specification detail:
"Can also be used to strip old sealer from inside a fuel tank"
https://www.frost.co.uk/paints-coating-plating/automotive-paint/por15-paints/por15-por-strip-paint-remover.html
You need the 'thin' version not the gel.
Good luck.
Regards Steve
Thanks Steve, looks just the ticket, when they have some i stock I will give it a go.
Hi Andrew,
Yup me too as I have some 'unknown' powdery coating inside my 650 tank.
However, once the muck is out, will prep for a POR-15 tank reline kit. Used before, brilliant and sets like rock. Had inside my Commando Interstate tank for 4 years, no issues. I just kept a little back in a sealed tin. The following day inverted the tank and hand painted the tank sealer around the filler cap, then let the lot dry for at least a week in the summer and refitted. No issues since. Just all about the preparation, take your time and follow the instructions to the letter. A good quality hot air gun is mandatory!
See how you go
Rgds Steve
