LAYDOWN (AND OTHER) GEARBOX QUERY
I've seen posts telling us how to reduce the end float on the mainshaft of a laydown (presumably applies to upright) g/box.
How does one increase the end float if no shims have been fitted?
George
There is a bronze thrust washer between the sleeve gear and the mainshaft 3rd gear. You will need to make it thinner. Try finding one which is worn thinner than the one you are using - failing that, machine yours down a bit. Be careful - you can't put the metal back later.
Another way to gain end float is possible if you have a pen steel washer between the main bearing and the gearbox shell. It's there to stop oil flowing out of the box via the main bearing. This steel washer is unnecessary if the bearing is shielded. No need to have two shields. If it is shielded, you can delete this washer, and gain some needed end float. If your main bearing is a bit worn, replace it with a shielded one. Rubber shield bearings are usually shielded both sides, and labled '2RS'. Remove one of them before fitting, leave the one facing the outside.
This applies to any Norton gearbox (pre-WW2 doll's head, vertical, and horizontal), but not the AMC box
Isn't this something to worry about only with roller (not ball) bearings? The alloy case expands more than the steel bearings inside it, so if it all spins freely when cold, surely it doesn't need any extra float? Unless of course yours is all jammed up when cold?
Thanks guys. I'll check out the hot float, if I can. @Paul - The bronze thrust washer is new. The new bearing has a built in shield on the outer edge but no pen steel washer. I left the inner shield as you suggested and left out the steel washer. This all follows a gearbox rebuild. The gear box is a laydown, mid fifties.
George
