Members, just another question on the brake drum, when I connect drum to the hub it does not fit flush with hub because the locating stud collar is too tight to fit into recess in hub. can anybody help in regards to this.
Denis .C.
Image may help Denis. Have…
Hi Howard , Denis has an…
Hi Howard , Denis has an issue with his rear Hub/drum interface , Possibly bad pattern or early/ late mixture of parts.
Thanks Robert, will have to…
Thanks Robert, will have to put a image up.
regards Denis.
Sorry Denis and Robert - I…
Sorry Denis and Robert - I saw the other Rear Hub entry first so assumed that this entry was for the front hub/drum/brake-plate etc. Woe is me. have a nice weekend. howard
Image may help Denis. Have you got the correct front brake assembly ? The locating stud is usually on the brake plate and it fits into the slot in the r/h fork slider. Cheers for now, Howard
