Hi, can anyone suggest what size jets and slide etc to use as an initial setup for a 650SS fitted with a pair of 928 concentrics please?
Thanks Keith
Are you planning on buying…
Pilot bush
I have 2 NOS 928 bodies, so had better look at the pilot bush, thanks I would never have thought of that.
If they are NOS then they…
If they are NOS then they could be 2 stroke and not have the pilot bush, with the expectation you screw a pilot jet into the bottom of the carb within the float bowel area. This was quickly dropped for 4 strokes as the factories found getting the bikes to idle properly. the fix was the bush in the bottom of the hole where the pilot mixture screw sits.
Are you planning on buying Premiers, if so then go for the 19 pilots instead of the 17 pilots. Standard 4 stroke 928's would be fitted with a 25 pilot bush which will work fine as long as they are cleaned by boring out with a 16 thou drill.
