Hi again everyone I have recently fitted new rear wheel bearings so thought I should do the drive sprocket as well and wish I had not bothered because every time I re-assemble something is binding, it feels like it is the speedo drive but cannot really be sure if I slacken the hub nut slightly everything is free, the new bearing is a sealed bearing so I have not replaced the seal and the bearing appears to be the same size, the speedo drive is perfectly free until nipped up can anyone suggest what I am doing wrong as it has me baffled, many thanks Chris
two possibles
Extra Speedo Spacer
Parts book has oil seal item 25 in wrong place - it is the other side of the bearing. I have had the speedo nipping up when everything tightened - solution was a thin washer (I used a copper washer from the oil pressure relief valve) used as a spacer between spacer item 11 and bearing item 23.
Thanks for your advice with…
Thanks for your advice with spacer which was also mentioned on another forum it appears to have worked I will not know for sure until it comes out of hibernation
Two things, firstly put the seal back in, worn out or not it may be acting as a spacer, secondly while reassembling check two tangs on inside of speedo drive are engaged in their slots and that they have not been crushed.
Good look spannering
martin
