Is it possible to fit a rear vernier isolastic without removing the engine?
Yes, may need some changes…
Thanks John.
Thanks John.
Photos to prove the point
Not much anyone could add to Johns super comprehensive work list so heres a few photos to show how far forward you need to get the engine and what access you get. This is a 1970 Roadster. Not everything that you see dissasembled was to change the isolastics.
Yes, may need some changes for a 71 as this is for a MK3 but I suspect you will be fitting verniers type anyway.
https://www.accessnorton.com/NortonCommando/isolastics-mkiii-vernier-servicing.840/#post-6048
