Hi, I’m in the process of renewing the complete exhaust system on my 56 99, it seems pretty straightforward although I have a couple of questions that hopefully someone can answer. How tight do the locking rings need to be? I have the hefty C spanner from Norvil, is that enough to tighten them? or does it need a tap or two with a soft mallet. Also I have some tab washers for the locking rings, they are a bit dished, is this correct or have they been damaged in transit?
Any help would be greatly appreciated,
Mick
I usually re-tighten mine…
The C spanner should be…
The C spanner should be enough. Sometimes I lock wire mine. But they don't have the Commando isolatics to pull everything apart with such enthusiasm. I use copperslip grease to help them assemble smoothly.
As above plus it can help…
As above plus it can help to undo the footrest silencer fixing and have someone to move it around a little to get the pipe well aligned with the head.as you tighten , then I wire them up.
Good advice (Dross Warning)
I agree with what you say Robert, except I believe wiring up or locking tabs is a matter of personal choice, as long as it works for you.
When fitting a new down pipe to any Norton, I start with hand tightening the rose and run the motor for a few minutes. Next tighten until meeting a little resistance with the C spanner. Then ride the bike for a few miles and tighten some more. After one more ride, with a hot engine, tighten one more time. Then bend the tabs over or wire up, your choice.
I learned the hard way with regard to my Commando. Tighten too much with the head not up to temperature and you run the risk of breaking the pipe flange.
I usually re-tighten mine with the engine warmed up - that way they've never come loose.There shouldn't be any need to use a mallet or to use tab washers - provided the threads are in good shape - just a good 'heave'.
Cheers. Ian.
