Widleline Rear Shock Absorbers
The NOC-shop are selling the EMGO 17-05589 for the NM20184 rear shock absorbers (for widleline Dommie 88 amongst others). Nice shock absorbers at a good price.
BUT - the rubber bushings and (particularly) the insert are too wide to fit the swinging arm. Swinging arm location is 19 mm wide and the insert on the bottom bushing is 24 mm wide. Top insert is 20 mm wide.
Any ideas where I can get rubber waisted bushings of the correct width?
Many thanks - as always..
Surely the club should be able to sort this out, being so different something must be wrong with the items supplied to the club spares scheme?
dan
