I have managed to fix most of the usual leak suspects but the sump ( which should be easy) has continued to frustrate me , I think the copper washers are too soft and are being extruded or crushed , I think a dowty washer may be the answer , have you found a good one?
Just need to find the right…
Just need to find the right size, metric ones can work better than imperial as more sizes available not just BSP.
