If you go on the Andover Norton main page https://andover-norton.co.uk/en and scroll down to the various models to choose from, the Wideline featherbed is the middle icon on the top line, and is a very standard 1955 Model 88. That is exactly my bike. The picture shows an air filter - to fit this machine, it needs to be slim and compact, there's about 1-1 1/4" clearance between carburetor and oil tank. So far, I have failed to find something which will fit.
Suggestions?
Pancake filter
Try this, Paul
https://accessories.hitchcocksmotorcycles.com/Amal-Carburettors/Pancake-Filter-Center-Hole
If you search 'Amal pancake filter' on the likes of Ebay there will be various other options, but you may need to check dimensions and carb fitting.
