Hi
1972 Commando, on the rear wheel, under a rather nifty bespoke “dust cap”,instead of finding a normal valve stem there is a solid threaded bolt. By solid I really do mean it is a cylinder of solid metal with a thread along the whole length outside. No hole for inflation or way to check tyre pressure. It’s completely sealed! It goes through the wheel rim the same as valve stem would. Anybody seen this before? Anybody know what and why? How do I get rid or am I missing something obvious? Help!
Robin
+1 for rim/tyre lock.
Had 2 (I think.) from new on my '76 T140.
Makes changing tyres "Interesting" and not really needed nowadays IMO (Or in 76 TBH.).
Removing it will leave a hole in the rim obviously, and they're pretty heavy so will have a large effect on wheel balance.
Yes! That’s exactly what it…
Yes! That’s exactly what it is! Thanks. What is amazing to me is I completely missed the less obtrusive normal valve stem elsewhere on the rim - my eyes were so drawn to the unknown! I do suffer from “man eyes”, so my wife says! Now I can happily finish my last bits of fettling before taking her on the road, new carbs and all. Shame about the wet sumping, think I’m going to fit a new oil pump and hope that does the trick - time poor so I won’t refurbish the old one, sounds like a mission!
She's correct
of course and the main reason we should never do housework etc!
I have Rim locks on both…
I have Rim locks on both wheels of the 99. I have had 3/4 punctures all in the back wheel . I managed to ride them all to a stop , one from 60 mph 2 up with camping gear at night raining on the MI, Was not easy. Would I have managed with the tyre coming off the rim and maybe jamming in the swinging arm ?. Who knows . Hope I never find out. If they were of no use I doubt Norton would have fitted them. Another spoiler, I have read that new pumps can wet sump just as fast as a reconned one. I suppose it all depends on the clearance between gear teeth and housing.
Wet sumping
Only 3 options:
1) Ride regularly. We never had this issue when the bikes were used daily..... OR....
2) Fit a proper Full Flow On/Off tap in the feed to the engine - such as the Feked one attached. This MUST be fitted with a micro-switch to cut off the ignition as one day (as many people I know have) you WILL ride off forgetting about it.... OR...
3) Drain the oil tank after each blat, AND put the can containing the oil on the seat, as sooner or later you WILL ride off without putting the oil back in.
Any idea what the bore size…
Any idea what the bore size of that feked Tap is?.
Fourth option
4) Get a Velocette-type anti-wet-sumping valve from Holland Norton Works. Tried and tested … (by me; usual disclaimer).
#H08 at https://www.hollandnortonworks.eu/en/exclusive-commando-parts
The rim lock is to stop the…
The rim lock is to stop the tyre slipping around the smooth chrome rim at low pressures used off road and then taking the inner tube with it and pulling the valve off. The tyre if its the right size and made properly even when the tube is fully deflated will not come off the rim but could drop inside the rim to the hollow for the spokes causing rapid deflation and you running on the rim not the tyre. If you look at modern WM profile alloy rims where the tyre bead sits they have serrations and the later still MT profile rims have an inner dam to stop the bead dropping in the spoke hollow for tubeless tyres.
If you fit bluetooth valve caps you can monitor the tyre pressures on the move and stop before they get too low so then you can throw the rim locks away.
Rim lock
I rode a 16h with no rim lock in a time trial in the Czech Republic a couple of the years back The rear tyre moved on the rim ripping the valve off in the process with the inevitable consequence involving a hedge. On my model 18 I have newish tyres and have upped the PSI a bit. Fingers crossed!
You aren't looking at the rim lock which stops the tyre sliding on the rim are you? It is fitted in the centre of the rim and is appears as a threaded stud with a lock nut.
