Hi all, I've sorted the electronic ignition and timing on my Electra now moving on to the starter. I have all the parts I need except the 3 sprocket pawls, pivot and engagement pins, the sprocket shaft washer that sits behind the circlip, the 3 studs that hold the outrigger plate to the engine case and the starter chain tensioner. Does anyone know the diameter and length of the two types of pin, the size and thickness of the washer and the thread on the 3 outrigger studs ( think the nut end is 5/16 BSCY but other end may be different). If anyone has any of these parts they are willing to sell please let me know.
Cheers, Stew.
