UK Supplier for Lightweight new pinion gears
Does anyone know if you can get new pinion gears, those in the NOC shop are second hand. Mine are pitted and worn. I would rather replace with new if possible. Might be cost is prohibative but without knowing condition of second hand stock, reluctant to buy as may be worse than those I have. Perhaps I am being fussy..
Andrew
Andrew:
Can you post the part numbers for the gears that you are looking for?
I will check my local suppliers here in Northern California for you.
Hi Michael,
Thanks for your offer, I will give outside EU a miss at the moment, customs and shipping will knock the prices out of the park, but again thanks for your offer. I will change the message to include location.
Andrew
OK Andrew
Let me know if you can't find them anywhere else.
Hi Andrew, I am not sure you will get new ones but Bantam John at Sheffield British Motorcycles in Staveley might be able to help you, the amount of stuff he has got is unbelievable, phone number 01246 281344. Hope this helps.
Howard
