1964 Navigator control cable lengths
Hi, I am at the point in my rebuild that I need to start fitting the throttle, clutch and brake cables. my bike has raised bars and I am not sure if the cables in the NOC shop are for straight or raised bars as no length is given in the description can anyone give some guidance, please
Steven
Hi Steven, I have bought replacements for all the cables on my 64 Navigator from the NOC shop and they were a perfect fit for the original almost flat, quite short handle bars.   When I replaced the original handle bars with Norton ‘flat’ bars which are about 1” longer the cables still fitted but with careful routing.   I suspect the clutch and front brake cables are probably the limiting factor, the throttle and choke offer more scope for higher bars.   I hope that helps.   Nick
