Unleaded Jubilee
Is unleaded fuel ok for the Norton Jubilee.
John.
Previously Gordon Johnston wrote:
Might be worth considering using super unleaded for the lower (in most cases) ethanol content.
Not sure that this is the way to go if you have a tank lineras the tank liner in my Electra was fine untill I had a need to use s/unleaded. The liner started to dissolve after just 52 miles, the blocked carb' that resulted from this gave me the pleasure of a two mile push home on probably the hottest day in 2012, not the best thing to do when you're 77 and clad in the necessary motor cycle kit.
