Good afternoon,does any one know the thread size on the damper rod ? thanks.
Front End Threads
Dominator Front End
Steering Column Stem 30026 13/16” x 26tpi
Fork Filler Plug 16998 1 1/8” x 20 tpi
Plug/Nut Damper Rod Hole B2/633 3/8” x 26 tpi
Steering Top & Bottom Nuts 15630 + 19490 13/16” x 26 tpi
Damper Steering Rod 15801 5/16” x 26 tpi
Top Nut 19490 15/16” x 26 tpi
Fork Mudguard Stud T1085 1/4" x 26 tpi
Some Mercury Forks parts have Commando UNF or UNC Threads
Slider drain screw
Drain Screw: 1/4 26 TPI
So you could use BSF or Cycle. But I think cycle was original, but that's my guess.
I have just replaced the drain screw washer on my famous forum pre F/bed Model 50 after a puddle of oil from the left hand drain screw. Reason was the fibre washer had split.
My advise is a new washer with every fork oil change.
I always...
.. give them a thin coat of wellseal as well as fibre washers seem harder these days.
Good afternoon ,does any one know the thread size on the damper rod,on short road holders,thanks.
