Rear wheel
Hi can anyone help me with a drawing or information of the back wheel spindle spacers and nut sequance on my navigator does the felt enclosed fittings back onto the wheel bearings
The parts book just shows one spacer on the speedo side 1? in long which is held in place with a nut, and there's a nut holding the brake plate in place on the other side. Prob best to look at the parts book to understand where all the internal bits go, but the felt washer seems to go in the enclosure cup.
dan
And here is the index to it giving some useful dimensions so you can check if you have the right bits.
Patrick.
File was too big to go in one.
scan0001-pdf
Patrick.
Thanks Patrick
The list with all the spacer lengths will do me to sort out the spindle build
I will have to see if i can get a parts list because i have a manual and the parts list ties it all together
Regards Steve
