Primary Chaincase Oil Seal
I am rebuilding my 1973 Interstate and am looking to find out if anyone has tried fitting a proper oil seal between the adjustment plates where the felt seal is located.  Previous experience with Commandos has always been that this felt seal is a source of leaks.  As I have new plates to weld in I was wondering if a conventional oil seal could be fitted and the plates then spot welded to hold it in place.  If anyone has tried this I would be interested in whether it was successful and which oil seal they used.
Something has to be pushing the oil past the felt seal. In my experience the root cause is a worn engine crankshaft oil seal. I suggest renewing this first before trying other fixes.
Thanks but I actually don't have a problem as the engine has just undergone a full rebuild by Norman White.  I am just trying to see if there is a better seal than a bit of felt that anyone has tried before I rebuild the original seal in the chain cases.
