Polyurethane paint.
Many ,many years ago I  brush painted my 99 with a polyurethane coach paint , supplied by Groves . I still have plenty of this paint but cant remember what undercoat/primer? thinner  is needed . I suspect its an ICI product  and probably contains Zylene . Any painters out there who can advise?.
... it was polyurethane? Most coach paint (tekaloid and the like) is synthetic coach enamel. This is quite accommodating for different primers - I use aerosol grey primer from Toolstation which goes on well, is easy to paint over and cheap!
You could be right Ian, too long ago, I'm surprised that the paint tins are  still ok after 30 years in damp shed . must be good stuff , one ! coat on tank has resisted ethanol and still looks ok.after all this time. Should be 3 coats .Paint brushes clean well with Wickes water soluble brush cleaner .
... your shelf life but the tim of Paragon black I bought 6 years ago for my ES2 still works very well for touch-up purposes although is too thick for anything more extensive.
As an aside I find Paragon much better than the old standby Tekaloid which I think has changed its formulation over the years. The last lot of Tekaloid I bought didn't perform well at all.
If it helps to identify the paint I have ,the shop sold me some retarder additive for the paint and it is an ICIAutocolour hi gloss 6    383  P850-1238.  Transport  Dont know if that helps , Probably a synthetic enamel.
The website encountered an unexpected error. Please try again later.
