Peashooter baffles.
Has anyone got any details/drawing of the baffling?
I'm currently building an exhaust system to fit my special, so this would help a lot.
Don't know about the baffling as never cut one open, but the central tube on the genuine ones has a series of scoops pressed inwards and pointing forwards to pull the exhaust gases into the outer chamber, noisier copies use a plain perforated tube.
 Last had a Commando 40 odd years ago John and bought a set of S/S ones, the baffles (From memory.) were similar/same as the originals that you describe.
 I didn't cut them apart either, but before I make some it'd certainly be handy to get some more accurate measurements rather than rely on my memory.
