Oil Tank Breather
Hello all,
I am using a stand alone air filter not the original set up on my 69-70 Norton Commando project.  I am using the original square oil tank that the breather went into the original air filter setup.
I am asking what size of fitting will work or can be mated to the exit on the oil tank.  Then I will add a filter to the end of that hose.  This project Norton will be mainly for off road desert use so I need to filter everything properly.
Thank you
William
