Does anyone know the OD of the valve guides, the guide in my head has fell out
I'm not sure if the head is oversize or the guide is undersize!
That's interesting.
Hi Dennis Its an old engine…
Hi Dennis
Its an old engine, when I stripped it down one valve guide was the same as yours (finger tight at best)
If the head is OS I will make a new valve guide, but I could do with the dimensions just to check!
If you are stuck, let me know I could make a few spares :-)
valve guide sizes
0.5010" - 0.5015" = original size of valve guides
Excellent, thank you
Thanks for your kind offer.
Thanks for your kind offer. I have used some special Loctite bearing retainer and I hope that will work. Good luck making oversize guides. There could be a market for them :-)
Dennis
I was going to try loctite,…
I was going to try loctite, but its just a bit too loose. Good luck
In addition to bearing retainer Loctite.....
.... - try having the outside of the valve guide knurled. Its an engineering technique to take up slack.
Here is some reading material on the subject:
https://www.hobby-machinist.com/threads/is-knurling-ever-a-workable-solution-for-bad-fit.75110/
Knurling cast iron
Is that possible?
Personally if no oversize guides are available, then it would be far better getting them plated with copper. If worried about them dropping through, machine a small groove in the guide where it comes out at the top and install a circlip. To go to one better with this, make a new spring seat shaped to hold the circlip down. Guide won't be going anywhere then. Remember that the guide helps get rid of a lot of valve heat too.
Please don't bodge it though, you may well regret it later.
Regards, George
I’m sure it would be easier…
I’m sure it would be easier to find another head, they are fairly common. I may even have one!
Dan
The suggestion that knurling…
The suggestion that knurling the O/D of the guides is not good idea. The fit of the guide in the head is critical to stop it moving and heat transfer between guide and head. With knurling there is no control over diameter, particularly with formed rather than a cut knurling. This will most likely mean that it will be over size on the O/D and cause further damage to the bore of the hole in the head, that is to say the knurled guide will "machine" its way in (even with the head hot), completely ruining the hole. The inevitable consequence will be a guide not held as tight as it should be and oil will weep down the O/D of the guide.
The only way to sort this is firstly check the hole is round and parallel, if it is make an over-sized guide. If not bore the hole round and parallel etc.
Loctite is not a great idea as it may well form a thermal barrier between head and barrel.
OP, the offers there to do the job properly!
I notice that the Club offer Phosphor Bronze guides, its not the best material for guides, Cast Iron or Aluminium Bronze (Closibro) are much better.
I’m sure I have some spare…
I’m sure I have some spare heads somewhere!
I'm going to make an…
I'm going to make an oversized guide, I'm not keen on the loctite idea as the hole is quite oversize!
Does anyone know the correct ID for the guides?
I think the guide valve guide internal diameter is..
I think the guide valve guide internal diameter is 7.12mm or 0.280 inches approximately 9/32". This was measured using a cheap digital vernier caliper so it may not be accurate enough for you.
The manual states 0.2827" as the "bore size" for the inlet and exhaust valve guide. And 0.2795/0.2787 for the valve stem diameter.
Dennis
Thank you Dennis, that's…
Thank you Dennis, that's very helpful.
What manual are you using, I've noticed some for sale on ebay but I'm unsure of the quality / info?
Jonathan, personal message sent through NOC
Jonathan,
I have sent you a personal message through NOC.
Dennis
That's interesting. Are they new guides? I ask because I bought some from the NOC shop and they are loose in the head of my Jubilee. Of course that could be due to wear in my heads but I am wondering what the solution might be. I can push the guides in by hand!
Not much point giving you the dimensions for my heads and guides if they are worn or undersize.
Dennis
