The gearbox on my December 1972 750 Commando has no serial number on the top? On the underside on 2 of the cases are the numbers 689 or 986 depending on which way up you read it. There are no signs of a number being ground off and the box looks entirely appropriate for the age of the bike. I wondered if the warranty replacement boxes had no number? Gearbox works absolutely fine just a little puzzled by the lack of a number. Any advice would be welcome. Thanks Paul.
If the two 689 numbers are…
Thanks Karl, the numbers a…
Thanks Karl,
the numbers appear if memory serves me right on the underside of inner and clutch side cases of the gearbox. I see what you mean that it might indicate matching cases like on the crank cases. I've seen crank cases without numbers but not gearboxes. Paul.
Previously paul_dudill wro…
Previously paul_dudill wrote:
Just to be clear, My 72 Commando has number stamped on top mounting lug rather then usual place on case for earlier models, you have looked there too?
Thanks Martin, I had check…
Thanks Martin,
I had checked there but couldn't see anything. I have now pulled the bike out into the daylight and low and behold the final 2 numbers are visible. These correspond with the final 2 numbers on the engine and frame. There appears to be a further very faint 3 digit number with a letter P I think. Did they stamp a shop and P for Plumstead on them, I thought they just stamped the gearbox with the engine number digits? The first numbers look like they've been worn away by breather/oil pipes rubbing against the lug over the years. Paul.
If the two 689 numbers are on the crankcase halves this was a practice done in the manufacturing by Norton. It was to identify that those are a matching pair and machined together.
