Hi, has anyone replaced their Navi rear springs, mine are different lengths, the dampers seem fine and the shrouds etc ok. Trying to find replacement. Girling book says they are 90 lbs and 8", NOC has a pair of Koni but seem to be for heavyweights or singles. I think these are 110lbs and 8" but I am most likely wrong. At about 85kilos, I am no lightweight so heavier springs might be better (especially as a fair bit cheaper than Norvil who advertise the same springs for all models - almost). Would the NOC ones fit be ok?
Andrew
You could try Hagon or Fal…
You could try Hagon or Falcon so long as you have the dimensions and spring weight they may be able to help.
