monoblock on a 16H
A friend of mine has a 40's 16H with a new Monoblock carb & adapter.
Not sure which company he bought it from but it doesn't want to run now, plugs wet indicating a rich mixture.
Has anyone done the conversion ,if so what jets are suggested.
ian
or no spark.
So check for spark before blaming the carb.
If you have good spark.
Pilot jet should be a 25 for a 4 stroke and the pilot circuit is the circuit used in starting with a closed or slightly open throttle. Turn the pilot air screw out 1.5 turns as a get you started figure and retune on a warm engine.
... a monobloc on my 1952 ES2 and it runs very well. I don't see any reason why the same shouldn't be true of a 16H.
As John said, I'd be checking the mag. Just out of interest why did he fit the monobloc?
The 376 was fitted by a previous owner and as it turns out the modified adapter is welded to the head. no choice but to run a 376.
Mag he says has plenty of spark. Could be carb to timing. I'll  be down there in 2 weekds to have  alook
Known to jam or stick down and make it run rich. 2nd float cover gasket 'cured' mine.
No mention of changing the plug? Has he run it successfully in the past? If so, and nothing has changed then the carb is not likely to go wrong.
just an update. I took a spare plug with me , adjusted the timing chain..valves and the mag points then checked the timing...I put my plug in and she fired right away.
Idling is a little erratic but not an issue..runs great though.
