Monobloc 376 choke slide is not fully going up still a bit about 5mm still showing is this normal
thank
Not normal, it should fully…
Had same problem with a…
Had same problem with a Monobloc. 10 mm down. Took the easy route and did as Bob and removed it. Tickle and starts okay. No idle before it had warmed up a bit. Otherwise no problem.
Could be...
.. that the tube is off a 389? I seem to remember that I had a similar problem and just trimmed the tube by 1/4" or so. I have a big box full of Amal parts so am never quite sure what originated where.
Not normal, it should fully retract. I would be checking the cable length. I've removed my choke slide, cable and lever etc and fitted a blanking plug to the top of the carb and just use the tickler to get it started as it never needed much choke anyway.
