Hello All,
I'm a new member and have recently inherited an original '66 N15CS with 4k miles. It's a treat to ride but I'm 5' 7" and getting shorter as I age. I've read the fork tubes were approximately 2" longer and believe the shocks are taller as well. Could someone suggest what Norton model fork tubes, dampers, springs, etc. and Matchless (I assume) model shock absorbers could be substituted to lower for road use without making permanent modifications . My apologies if this has already been covered. Thanks in advance for any help and advice...Bill
Rear shocks
I would suggest that changing the rear shocks are your best option as the CS had longer shocks than the other G/N15 range, having seen inside a late'65 N15CS forks the dampners are special [2 way damped? ] and different to normal Norton's so I suggest don't muck with them.
Changes
If the rear shocks are shortened or lengthened by more then a small amount then the run of the rear chain will change and possibly touch the swinging arm.
At the front end shorter stanchionscan be fitted but this can bring the standard mudguard nearer to the front downtubes and cause issues when braking hard.
How about obtaining a set of smaller diameter wheels (17") and not riding over speed humps too fast?
1966 N15CS
The 1966 N15CS, has the later standard Roadholder internals so it would have the internal springs with the standard type dampers. These internal dampers were an inch longer than those used in the Atlas and 650ss models. The only models of the N15CS, G15CS that used the G80CS type front fork internal were used from 1963 to 1965. The rear Girling units are about an inch longer on the N15CS so you could fit the Matchless G15 Mk2 or the Matchless G15CSR rear Girling type units. The 1965 G15CSR bikes used 18 inch wheel front and rear wheels. I have seen N15CS and G15CS bikes use the Commando length fork stantions, but the handling may be a tad off. The stantions on the N15CS are 25 inches long or 24 7/8 inches long.
N15CS115000
Anthony,
Thanks for the helpful response and info. For whatever reason, the fork on this machine seems to be a Long (?) Roadholder definitely with external springs but has gaiters instead of the steel cover tubes. Private engineering from a previous repair, or is it not really a '66 as titled? Sourcing shorter Girling units seems easier than sorting the fork. Any further assistance will be appreciated!
I would not be shortening…
I would not be shortening just the rear shocks if the bike has already been modified to be taller at the front, you are just going to amplify any adverse effects. I would be lowering both front and rear.
New boots would be the answer?
Sorry, one too many sherbets tonight!
