I may have a problem brewing and would welcome comments from the wise.
My 1956 Dominator 99 is running fine with the exception that the gearbox has started to lock in first gear when I come to a stop and it takes a lot of juggling and force to get it out and into neutral. Ok, I hear you say don't come to rest in first gear but many times one needs to come to rest in first to aid manoeuvring the bike to a parking position.
Is it possible to investigate this symptom without having to remove the gearbox and what is the likley cause of the problem ? I understand that I have to remove the engine to get the gearbox out and I am not looking forward to that if indeed the engine does have to come out as well !
George
Hi George, It sounds very…
Clutch
Evening Robert. Thanks for your response. Whist I understand where you are coming from, I have had no problem hitherto with the Bob Newby clutch dragging and since it's installation it has operated perfectly. Having said that I will double check it in the morning. I assume that after the usual freeing of the plates via the kickstart lever, if after putting the gearbox in gear and pulling in the clutch lever , if the rear wheel rotates freely then the clutch is not the problem.
The simplest test is to pull…
The simplest test is to pull the clutch in and kick the bike over. A good clutch should offer no resistance at all and spin really freely. Another possibilty is that you are getting engine oil passing the crank seal and affecting the clutch, I am having some of that myself ,I am having to drain off the excess after every ride , time for a stripdown.
Its possible that the sleeve…
Its possible that the sleeve gear bushes have tightened which would have the same effect as a dragging clutch. All reasonably easy to fix.
Hi George, It sounds very like you have a draggy clutch . There has been plenty of posts on how to improve your clutch.
