Hi, Just bought a 99 that needs a little work. The kickstart hits the exhaust pipe under the gearbox. Is this a common problem or will another type of kickstart solve the problem.
Also, which Handlebars are correct for a 1960 Dominator 99. Straight or slight rise.
A common issue, The…
A common issue, The orriginal std KS is a non swivel type that has a good offset ,however some replacement folding types have less offset and pattern replacement pipes can have an imperfect line. You may have a bit of spare clearance between silencer and frame tube that will allow the pipes to be pulled in. Orriginal pipes also had a slight kick up under the box .not usually replicated in pattern stuff. The bars fitted to the std Dommy had a 2 1/2" rise. and were drilled and tapped for the dipswitch/horn screws. Pattern pipes and silencers sometimes needed a dent to clear the frame tube.
