Please someone help with a query. Try as I can I cannot release the contact breaker assembly as it seems to have stuck tight to the outer housing. I have tried putting the centre screw back in about one inch and moving it about but still no joy.
If you dismantle the magneto…
If you dismantle the magneto and tap the rear bearing housing off of the bearing the points assemble will come off with the housing,with the points bolt removed of course.
The contact breaker assy is tapered to the armature and twidles round with the armature. So how can it be stuck to the housing? The housing having a cam ring, which operates the points as it turns.
