Nearly finished my loom re-wire. Can anyone shed any light on the spare Brown / Green wire in the picture. It comes out of the Tach/Speed/Pilot terminal. My guess is it's an earth to the headlamp shell but in that case I would expect it to be red? Thanks
2016-01-17-14-04-25-jpg
That attachment is 0KB. It…
On a mk3 commando the brow…
On a mk3 commando the brown / green wire goes to the rear lamp
and the tacho lamp and the speedo lamp and the piolet lamp and back to the master switch the other end of the tacho lamp speedo lamp and the piolet lamp go to the red wire.
regards
Bob
If its a Canadian import this wire also goes to the warning light unit so the lights come on when the engine is running
Previously Jonathan Soons…
Previously Jonathan Soons wrote:
That attachment is 0KB. It is invisible.
Thanks Jonathan - I have reattached photograph. Regards
Previously robert_wright w…
regards
Bob
Thanks Robert. I have reattached the photograph to help. Regards
Hi turn the ignition switc…
Hi
turn the ignition switch on and then 1 more to the right
if no lights its probably the wire to the ign switch
or if the lights come on see which one is not working and this will be the wire.
hope this helps
Bob
regards
Bob
Thanks Bob
It was the tacho pilot light
Victor
Thanks Jonathan
Victor
