Good morning and thanks for having me.
I have recently been gifted my Dad's old Norton Commando 850 Interstate, '73 I think,
She has been sitting 36 years (I am 36) the engine was rebuilt 9 months prior to being parked up.
I dug her out from the back of the barn last weekend and its not a nice sight! Someone has taken bits off and swapped bits over, my Dad does not think it's his tank or seat. Both were just sat on no bolts in. The clutch was off and in a bucket all footpegs were off and pillion pegs missing , looks like a lot is missing on the electrical side too with wires hanging everywhere.
Anyway its my first British bike and am looking forward to getting out on it
Sorry for my bad spelling not my strong point
30 years sitting will have…
Yes the tyres have gone hard…
Yes the tyres have gone hard as nails but surprisingly held ther air ,
Welcome to the group and…
Welcome to the group and good luck with your new project. There are lots on here that will be able to answer your questions so don't be afraid to ask. We all love a project so please post pictures as you get on.
Iv done just that this…
Iv done just that this evening 45 minutes of polishing and can see a good result
Your oil tank will be empty,…
Your oil tank will be empty, the contents will be in the sump of the engine and in the crank chamber, So when changing the oil more will come out of the sump than the tank.
Hello Christopher, Are you…
Hello Christopher,
Are you thinking of a full strip down and restoration or just the minimum to get it running at this stage? A word of warning! Just because an engine has been rebuilt before laying up doesn`t mean it will be ok now, it very much depends on the storage conditions. A mate of mine was in exactly the same situation with a Tr1@*ph, the engine had just been rebuilt before laying up and assured by his dad it would be ok he restored the rest of the bike without stripping the motor. It would seem that rust must have started forming on the main bearings so after using it a few times, the drive side bearing picked up and smashed the crankcase! If your bottom end is full of oil as suggested, this may not be the case but I would still consider an engine strip and assessment and fit new mains and seals.
Regards, Al.
I was thinking a minimal…
I was thinking a minimal restoration just to try get it on the road and then work on tidying it up as I go along. However that is a good point, maybe an engine strip would be a good idea. Although not sure if I am upto the task just yet - must get reading the Haynes Manual!!
The Haynes manual is mostly useful…
The Haynes manual is mostly useful for the pictures; some of the data and advice is unreliable.
You need (all equal priority)
- Workshop Manual
- Parts Book
- Norman White's new book
Free e-versions of the first two can be found on-line.
The Andover Norton site is developing a useful collection of instruction leaflets.
The Clymer Manual has…
The Clymer Manual has clearer photo's that the Haynes (it's printed on better quality paper), look for a pre-loved one on eBay/Amazon/etc (there's also a version covering BSA/Triumph/Norton, but it is abridged for each marque).
Also recommended, the dvd's produced by the NOC with Mick Hemmings.
Good Luck with the recommissioning!
+1 for the Hemmings videos
I should have remembered these. They are just as essential as the Workshop Manual, etc.
The wife has just bought me…
The wife has just bought me the Norman white book , I look forward to it arriving, were is the best place to get a parts book ?
Thanks for the advice
Parts Lists are available…
Parts Lists are available from Andover Norton. You can get online copies from several websites.
http://www.classicbike.biz/Norton/Parts/NortonParts.htm
I’m also rebuilding a Commando, and personally I don’t think you can have too many manuals!
I know I am like a stuck…
I know I am like a stuck record on this subject, but I would urge you strongly to strip the crankshaft and clean out the sludge trap, you will need to do the mains anyway unless the engine has been regularly turned over.
If there is sludge in the trap and it has dried out, it will break up up and block the oilways after a few miles, I have seen a couple of 'time capsule' bikes destroyed in this way.
Good luck with the rebuild!
No the engine has not been…
No the engine has not been turned over
I will strip it down and rebuild it thanks for the advice,
Parts List
The Parts Book is online at Andover Norton & can be used for identifying & ordering parts. I would still suggest a hard copy tho'. I have 2 copies, one for the garage (grubby one) & a clean one on the bookshelf for browsing (possibly a bit sad really).
One of the advantages of the Norton Workshop Manuals & parts lists is that the line drawings make it easy to photograph & print the relevant workshop manual pages & parts diagrams for sticking to the garage wall for reference when undertaking more complex tasks that jump around the manual (e.g. head removal/replacement, gearbox strip) - this aide enables me to annotate & check things off as required (& keep track of progress, useful if a e.g. family/work emergency intervenes with the critical part of our lives).
30 years sitting will have rotted out most of the rubber parts especially the tyres
