I have discovered the gearbox sprocket on my 1959 model, is very hard to turn ( chain off ).
It seems from some research that the gearbox cannot come out unless it's with the engine. Damn. Can someone confirm that please, and any pointers as to what may be nipped - the previous owner said he had recently had the gearbox rebuilt (by someone else), I now have a parts book (of sorts) but it does'nt appear to show any shim locations.
More work........
Regards, Terry.
Most of the internals can be…
Dommie gearbox
Thanks Robert - I feel much better about the job to come now ! I found the on-line "Jampot " AMC gearbox article last night, so when the manual arrives as well, I will be fairly well prepared. It changed gear OK, smoothly and silently, so , hopefully, no damage done yet.
Thanks again.
There are also a few other…
There are also a few other possibilities , I expect others will chime in soon.
I look forward to any advice…
I look forward to any advice that comes this way, in the meantime, since the swingarm silentblocks seemed almost totally resistant to movement, I've just bored and turned some bits up to press them out. My sons' press is only 10 ton, but surely .....?
Will know this afternoon !
Hi Terry. I rebuilt my…
Hi Terry. I rebuilt my Dommie 99’s gearbox and found that the drive sprocket was ‘difficult’ to turn. After a lot of measuring and fiddling with seals etc, I found that with the (new) seal in place but WITHOUT the metal spacer ring fitted into it, the gearbox sprocket turned very easily. When I put the metal spacer ring back into the seal, the sprocket was once again a lot more difficult to turn. So it seems that the problem (for my gearbox) was very tight interference clearance between the lip of the seal and the edge of the spacer ring. I removed two thou off the outside of the spacer ring and it helped make things easier to turn. I’m sure it would be even better if I removed more metal but I don’t want to risk making an easy path for an oil leak past the spacer ring.
Before attacking the…
Before attacking the silentbloc swing arm bearings, I suggest you search this site for comments, warnings etc. When you say "they don't move", what exactly were you looking for? The rubber seems to have nearly indefinite life in that application. They only "move" by twisting the rubber between the outer sleeve, fixed in the swing arm, and the inner sleeve which should be fixed to the frame by tightening the spindle bolt. Lots of blood, sweat and tears have been shed by owners trying and eventually succeeding on changing them, for no very good reason.
Has anyone here any reports of improvement in anything after replacing them?
Thanks to Tony, above, that…
Thanks to Tony, above, that's the first thing I will check.
David, I just don't like silentblocks for a motorbike swing arm. It's simply an easy non-engineering way for the makers to eliminate play . OK, there's no future adjustment or lubrication required.
It's my intention to go for a plain bush in either self-lubing engineering plastic or PB, maybe even needle rollers though they're not really needed for a classic road bike ( and would involve even more engineering).
Those old silent block bushes were solid, restricting suspension movement, they are now OUT, safe and easy in the press with the bits I made up. They are marked Clayflex so I assume they're originals. Certainly are long lasting, they just don't let the suspension work.
No going back now, bushes it is !
Silentblocs
Hi Terry,
I, like you, thought that the silentblocs were, from an engineering standpoint a poor choice for a swinging arm pivot and mine were over 30 years old when I was resurrecting my bike, so I designed and made some bronze bushes, sleeves with seals and added an oil supply to them.
It works very well, but having completed it, I found it made absolutely no difference to the way the rear suspension behaves and is simply another maintenance task to keep up with. Really wish I hadn't bothered, and if/when they wear out I would go back to silentblocs in a heartbeat.
When you do the sums, with standard shocks there is less than 4° radial movement up and down for the swinging arm from fully compressed to full extended - well inside the elastic limits for the silentblocs. As for any sideways 'flex', with the swinging arm width/length on a featherbed that too is minimal - certainly a lot less than the tyre flex you get with modern tyres.
Lesson Learnt for me? Unlike lots of things with a Dommi, this is one of those 'If it isn't broke, don't try to fix it!' items. Proper bushes or needle rollers make sense on a modern bike with maybe 6" travel suspension and long swinging arms but on our old clunkers? Still, you are on the way there now so good luck.
Hope that you get the gearbox sorted.
Regards,
George
Thanks for the advice George…
Thanks for the advice George but as you say, I'm on the way already. I accept what you say about only 4" (ish) travel, but my silentblocks only allowed 1" easy travel at the fork end, 1.1/2" if forced. Having arthritis in back and hips, I don't like harsh suspension.
They were definitely restricting suspension free travel. I've decided to use Ertalon, or whatever our local stockist has mighty close. No maintainance required once fitted. I'll incorporate weather seals at the ends.
The mod will certainly out last me without further attention !
Most of the internals can be accessed without the box removal. Its possible that someone has replaced the layshaft driveside ball bearing with a roller bearing and shimmed the KS end (with Commando Isos shims ) and not left clearance . Easy to do (done that!) . The shims need the ID increased to fit properly. Will not be shown in parts book. Try just taking one out , A bit of end float is normal.
