Dominator service notes
I have been reading through this wonderful publication.
And been looking at brake pedals for various twins and singles. This is a minefield. The service notes do not cover this topic. I was wondering if we could start a picture index of known pedals. Maybe useful when searching the jumbles.
The reason for this is that I bought a late wideline pedal and discovered the pivot hole too small but in all other dimensions, it is identical. I believe it is for a single down tube ES2, which uses a pivot with a nut to retain the pedal. The exception is the late 57 ES2/50 with the tubular lower rails, I believe is the same as a wideline.
Any input welcome​.​
Paul.
Hi Paul.........your posting re. Brake Pedals was one of those areas where finding somebody who knew all the answers proved next to impossible. This is one of the reasons there were so many contributors to the DSNs and even then there were still gaps, goofs and gremlins in the early editions.
We knew from the Factory Parts books that there were various versions of Brake Pedals but not the detailed changes. Main and Side stands was another Chapter that proved difficult to research., with Export only Models adding to the list of variations.
Hopefully, other NOC members can help fill in the gaps and future versions of the DSNs will become even better in terms of content and accuracy.
The website encountered an unexpected error. Please try again later.
