convex mirror
I'm searchin for a stem mounted mirror with a convex glass, rectangular or round.
Any idea?
Fritz
Previously les_howard wrote:
The Napoleon bar End mirror.
...Best bar end mirror ...
Stem mounted, not bar end.
Fritz
Fritz
Oh dear.....only trying to help.........how charming!!!......Pleeeeese forgive me...Frown!
Les
My Triumph street triple has a decent pair of mirrors and many owners get rid of them to fit dinky little bar end ones, so they regularly come up on ebay for not much. I think they would look ok on a Norton. (I did have to make up a 1" extension to get a view past my elbows)
Try looking for Lambretta or Scooter mirror heads, all the ones I have seen have flat mirrors but at least most of them are stem fit so worth trying to track a convex down.
Thanks Gordon/Fritz, that looks as if it will do the job. I shouldn't have missed that one, but nevertheless, I did. They'll wonder why the sudden interest in their mirrors. I couldn't find anything similar at Stafford last April - embarrassing as I believe Halcyon had a stand there!
Previously Chris Grimmett wrote:
â?I couldn't find anything similar at Stafford last April - embarrassing as I believe Halcyon had a stand there!
I don't know why this type of mirror isn't a requirement in our scene.
But anyhow, Chris and me got a solution, thanks Gordon.
Fritz
I'm glad they aren't compulsory - I hate the things for giving confusing distance information. I'd rather move my head a little bit sideways.
I've received mine rigth now.It makes a good impression to me.The clamp and the associated screw is made of stainless steel and looks very stable.The mirror itself is mounted in the housing with a rubber edge.
Fritz
â?
Just fitted a Halcyon bar end mirror to my 16H - after scary moment on A3 with van unexpectedly passing far too close...
It's convex (annoyingly as far as I'm concerned). Very well made. I already have one on my Dommie - after wasting money on no less than two previous cheap ones that either broke or refused to stay in the right place.
Just a warning: the (prewar?) bars on my bike have such thick walls that the hole is only 17mm. The plug on the mirror is 17.5mm or thereabouts. So I ended up mounting the three parts on a mandrel in a small lathe and turning it down to fit. It's very easy since those bits are alloy. But would be a bit of a problem without a lathe.
I've no idea how thick bars usually are. But I doubt if they many are asthick as mine nowadays.
Before the 1950's, nobody used mirrors on motorbikes. So whatever I do is going to be wrong. But the round ones look better to me on an older machine.
