Commando 850MkIII Modified Circuit Diagrams
I have attached sheet one of the modified circuit diagram for my 850 MkIII. Sheet two to follow.
I have Pazon Altair ignition. Boyer Power Box, Al Oz ignition warning light, Relay switched headlamp, electronic speedo, electronic rev counter.
Superflous wiring is removed.
commando-sheet-1-iss-1-pdf
Tony,
all looks very tidy.
You don't indicate the connection numbers on the 4 pin headlight relay units though.
I fancy doing that mod and those details would help.
BTW
Pazon Altair was a good choice, transforms the bottom end engine power with maximum ignition advance happening just over 3000rpm.
Previously gordon_robertson wrote:
Tony,
BTW
Hi Gordon,
The pinout totally depends on the relay itself. If you find a sutable relay, such as:-
https://uk.rs-online.com/web/p/non-latching-relays/0476583/
Then it is obvious how to connect it.
In order to increase the life of your switchgear, it is good to have a reverse biased diode across the coil. something like:-
https://uk.rs-online.com/web/p/rectifier-schottky-diodes/6288931/
There may well be 'ready made' headlamp relays out there that you can use but I built my own system.
