Commander Batteries
Commander batteries
The Commander came with 2 x14amp/hr batteries, eg YB14. Two batteries were installed to give sufficient power for all of the police equipment. Some owners have reduced it to one battery without any problems. There is no reciprical motion so the engine spins freely but starting does require a fast spin.
Commander batteries
The twin batteries on my Commander lasted seven years.There is no real reason to to reduce to one.Like Tim said not much compression but when hot the engine likes a good old spin.
Why compromise.
thanks for that tim much…
thanks for that tim much apreciated i supose with there not being many made theres very few in forums etc think i will get 2 this time
thanks again trev
just another quickie tim if…
just another quickie tim if you just use one battery which side do you use if you were sat on the bike and what do you do with the other battery leads i might by one lithium shorai which i have on my other bikes 220 cca i also have a genuine charger for them
regards trev
meant to say in first post…
meant to say in first post motobatt was fitted to my kawasaki vn1600 classic not my classic bikes there shorai
Commander Batteries
I use just one Exide YB14L-A2, fitted on the right hand side I removed the redundant positive lead and retained the negative lead connecting it to one of the allen bolts that hold the left hand carb to the frame.
The vacant space where the left hand battery used to fit now holds a useful 1 litre container of oil.
I have had the same battery for a few years now and do not have any starting issues or lack of power.
thx anthony i have bought 2…
thx anthony i have bought 2 new gel batteries as bike has not been started for a few years upon advice ihave filled cylinders and am turning over manually so im tols will need a lot of turning over to get going
regards trev
Gel Batteries
I fitted 2 gel batteries and they stay charged for many many months without use and before i start the bike after a winter lay off i remove the right panel and turn the fuel tap between on & res and you will find that the carbs will fill with fuel without waiting for the vacum to turn the tap on and mine starts first time.Cheers Paul
Hi all
New to rotary bike having just sold my immaculate home built Triton that is on ebay for sale £19,999.00. I decided i needed a challange so i bought a Commander on ebay at right money. What is the battery number do i need? I intend buying Motobatt batteries as i have them on my other classics and they're a good battery - lots of power.
I want to get these on order so i have them when bike comes although i wont be starting it till ive done the pre starting sequence - ive been told by mechanic
Regards - Trev
