I recently bought replacement camshaft bushes from one of the big spares houses. I took my crankcases, the (new) camshaft and the new bushes to my local engineering company (who I have been using for engine work for several years) as I wanted the bushes to be installed and then line-reamed once fitted.
I received a phone call today from the engineer who said that he wasn't comfortable fitting and line-reaming the bushes I'd supplied. He said the reason for that is because the bushes I bought are supplied pre-sized and honed to give the final camshaft running clearance of 1.5 thou. Therefore, any slight misalignment between the installed bushes due to slight out of line bores in the crankcase halves or due to changes caused by heating the crankcases cannot be removed as the bushes will then either have oversize bores or unevenly sized bores.
Does anyone know if it's possible to purchase undersize camshaft bushes from any supplier?
unsize bushings
Camshaft bushings
Hi Anna,
I am rebuilding my MK3 commando and i assume the above method would also apply to mine as well. Sounds like a good plan to me, most helpful.
Kind regards, Ian
Grinding paste REALLY?
Are you seriously advocating using valve grinding paste in bronze bushes? Bronze is relatively soft, and the paste will bed into the surface and no amount of washing will ever get the residual bits out of it, meaning that it sits in there wearing away your nice new cam.
Is this why you have so much experience changing bushes?
I would never let you near one of my engines!
George
over reacting
hello well I think someone overreacting you get the bushies clean with no problems with you cleaning bath yours anna j
I'm with George...
... grinding paste should never be let anywhere near bronze bushes.
bearing scrapers
hello now what do you think bearing scrapers are for when we rebuild a Kelvin K4 we have to use a Bearing Scraper to scrap a bronze shell bearing to shape and then lap it in with valve grinding paste fine then wash off in clean diesel and Kelvin Large ends have shims at ether end of of the conrods side shims these sometimes are bigger than needed so we have to shape them to fit , you cannot get off a ship in the middle of the Atlantic you have to utilize what you have to hand and make it work some of you have not lived, I had to make shell bearing and bronze bushings from scratch In my time anna J
Scrapers yes...
... grinding paste no. I'm sure you got away with it Anna but it's still the case that you'd never be able to get all the grit out of soft bearing metal.
And
Ian is absolutely right. Scrapers or reamers yes, abrasive compounds no.
There is a huge difference between a 120rpm ship diesel engine and a 7000rpm bike engine.
Anna, I wonder what your oft quoted craftsmen in Bracebridge Street would have made of your "grinding paste is ok" bodge?
I bet you would have been laughed out of the shop.
George
Thanks to all who have…
Thanks to all who have contributed opinions and advice. I wasn’t intending to start a heated discussion. I like Anna’s idea for inserting the bushes - that sounds achievable even with my limited experience. However, I’ll hold off using any grinding paste as the number of votes seem to advise against it. With any luck, the camshaft will fit well in the bushes without further metal removal.
Thanks again.
fine laping pastes
hello You guys I think you all need to read practical machinist or Newman tools websites on lapping in hard bronze and you find the quick way of lapping in with fine lapping paste silicon carbonate fine ground is the same as Clover fine lapping in paste and Norton Camshaft Bronze bushies are made in Hard Bronze if there were not they would not last very long So some of you are overreacting and need to read up on lapping in valves and bushings you only use a very small amount just to lap in and free up the bush then you can wash it all away with your paraffin gun at 40 psi with white spirt in, and you can clean up hard bronze with fine clover lapping and grinding paste which is used for valve lapping in too and other jobs,and you can also use chrome cleaner too for lapping in I done more engineering then some you has hot dinners in the last 50 years , A old bike and a Old bugger riding it, Yours Anna J
Over reaction, No not at all
Do not allow any form of grinding paste near bronze bushes that have a shaft revolving in them. You will wear them or the cam out prematurely.
Plain bronze or white metal bearings are machined and then scraped to fit. (in the case of our cam bearings, being line bored after fitting)
In the course of my working career i have had to machine quite a few large and not so large white metal bearings for steam turbines, electric motors and pumps and the like. The use of grinding paste anywhere near these would have got you fired.
Grinding paste does have its uses but this is not one of them.
One does wonder, Anna, if all your 'engineering' is the reason why your bike isn't running?
Not true
Hello Peter both my bikes are in running order mate and you're wrong about lapping in paste on hard bronze engineering companies have been using it for years or they would not have bothered making lapping paste in the first place And try reading these threads first And do your research and try to learn something. Yours Anna j
Reason's why
Hello Too all there are reason, s why I have not ridden my bikes of late Has I have a number of health problems both my Norton will run when some fuel is added in the tank and oil turned on. And a good kick over they start and run. With no doubt. Yours Anna j
Colgate - Gibbs - Macleans
When I did my apprenticeship toothpaste was recommended for easing tight fitting components.
HAPPY CHRISTMAS to all you…
HAPPY CHRISTMAS to all you Norton enthusiasts. Keep going, Anna, always entertaining... Rolls Royce used jewellers' rouge to lap their timing gears until they were silent. Norton certainly did not, you can hear mine a mile away, above the clatter of the tappets! (1959 Dommi 99)
Timesaver lapping paste
I have posted this here, instead of the 'motorcycle lockdown' thread as it directly follows on.
In her first reply on this thread Anna states to use 'valve paste fine' when easing a tight cam bush.
When brought to task on this advice Anna took umbridge and eventually posted info on a company that supplies a product called 'Timesaver lapping paste'
Having looked at the Timesaver lapping paste info on the Newman tools Inc website (for those who don't know what this is, it is claimed to be a non embedding abrasive lapping paste)
This is a completely different product than the 'valve paste fine' that she purported to use. Valve grinding paste is a silicon carbide paste specifically used on grinding or lapping in the valves on IC engines.
I suspect, that when Anna was pulled up on her advice, she trawled the net looking for info to use as evidence that 'her advice' was good.
Hi Tony how was this…
Hi Tony
how was this problem resolved, Im having similar problems with my Commando bushes
Hi Marcus, In the end…
Hi Marcus,
In the end things worked out ok. If the camshaft is put into just one half of the crankcase (doesn’t matter which half), then there is a tiny bit of side play between the bush and camshaft but when both crankcase halves are bolted together, the camshaft fit is perfect with no side play at all.
I haven’t yet built and run the engine so I can’t say what the long term state will be. I’m sure there will be people out there who will predict imminent disaster just around the corner, but I’ll wait and see how things go once the bike is in the road.
Hope that helps.
Thanks for the reply Tony,…
Thanks for the reply Tony, did you see my post in the Commando section?
Hi Marcus. Thanks for…
Hi Marcus. Thanks for pointing out your post in the Commando section. It does seem strange that the bushes are finished so close to the final tolerance but I guess (for me anyway) that only time (and miles) will prove if it’s a problem or not. Hope you get your ones sorted out.
Line boring and reaming
In theory crankcase are assembled then line-bored, so finished bushings should need minimal finishing to fit - if they have been made to the correct tolerances needed in the first place.
Where has Anna gone. ?????
She hasn't posted for a while.
Anna. I,m told she has been kicked…
I,m told she has been kicked off the website, i can hazard a guess for making inappropriate comments. She has lurked around on the Accessnorton forum, her last post there on the 4/1/2021
I agree with Lionel the bush…
I agree with Lionel the bush houses should be perfectly concentric after manufacture. If the cam spins freely in new bushes, with detectable play, that should be fine.
Sorry to drag this out of…
Sorry to drag this out of the past again..but I'm planning a good look inside my Dommie when the nights draw in again. There are a couple of reasons - I'm not happy about piston clearance although I must do a plug chop first to see if the main jets might be bigger.
But by using the listening trick with a variety of sounding rods, I'm thinking the cam bushes might be worn. A bit of YouTube "research" turns up a method for Triumphs - with a tool - but their drive side bushes are smaller. Is there a Norton tool?
The method they use explains why the bushes are such a small amount undersize. The cases are bolted up,with the drive side bush in place but not timing side. A parallel reamer is put into the entrance of the drive side bush, A steel flanged guide bush follows onto the parallel shank of the reamer. This holds in in line. The bronze bush is then reamed by hand. It's only a very small amount so it's not hard work - no need for machines.
Then the timing side bush is fitted. Now the clever bit - a hard ball bearing is gently tapped through the timing side bush! Otherwise of course there's no way to guarantee alignment of the reamer.
It should be fairly easy to make up the tool using a standard reamer of the correct length and making a guide bush on the lather - but is there one on the market? I imagine a 7/8" ball bearing could be bought somewhere.
Maybe of course the bushes are OK anyway! Apparently it's not uncommon for the old camshaft (if it's OK for re-use) to fit into new unreamed bushes, because although most of the wear is in the bushed, a small amount occurs on the camshaft.
Does the above match others' experiences? Otherwise it's a machine shop job - if only there were a few machine shops left in England.
hello now do try Rodger At RGM Motors will give you some guidance on bronze cam bushings. But how I fit new camshaft bushies is by heating the cases in the oven with two case half screws in the bottom and the 1/4 nut and bolt at the front for quick disassembly then when very hot you unscrew the two bottom case screws and the 1/4 nut and bolt at the front of the cases and on a wooden chopping block taps out the bronze bushies with a leather hammer with a couple of taps they fall out then back in the oven after a quick clean of the case then have ready the two new ones to fit back in the same way they came out but you need the camshaft with heavy grease on the end and fit the bush over this and tip back in place with you leather hammer no machining need all that needed is some fine lapping paste and rub in with the camshaft end to bed in the bushies then try fit the two case halves and 3 bolts and try his out for fit and free play if you have free play at each end then you next job is clean every thing down and oil up the bushies to reassemble the engine. the bushies should fit inline if the cases are matched correctly, And you may have these made, that a machine shop in bronze, And do make sure when fitting make the oil holes line up with the cases oil holes at each end. yours Anna J Dixon
