Last winter I coated some chrome and paintwork with ACF 50 , I used the aerosol foam and the liquid small bottles. It did a fantastic job ,and even dissolved some rust back to bare metal and got corroded electrical connections clean . But now I want to remove it and there is a problem !.Its dried to a hard laquer and is resisting me. Any ideas as to a solvent ?.
Perhaps a fresh application…
Hi Geoffrey, Yes I was…
Hi Geoffrey, Yes I was thinking of that, I wanted to warn others of the problem, its particularly annoying if you get it on mirrors or speedo glass.
MSDS tells us it is soluble…
MSDS tells us it is soluble in Naptha.
http://www.acf-50.co.uk/acro2017/ACF-50%20BULK%20LIQUID%20MSDS%20_%202017%20_%20ENGLISH.pdf
Naphtha is the US name, in…
Naphtha is the US name, in UK is its called lighter fluid.
There you go. I knew one of…
There you go. I knew one of you would know, saved me rubbing my paint off with celulose thinners or worse. Thanks. I'm certain I have a can from my camping days.
I thought...
... lighter fluid was petrol?
Lead free petrol. A possible…
Lead free petrol. A possible alternative would be solvent brake cleaner. I saw some for sale at Kempton but when I asked for some at a motor spares place it seemed to ge a more 'environmentally friendly' detergent type...O think.
Perhaps a fresh application of ACF50 will dissolve the lacquer ?
Worth a try on a small area.
