Has anyone got or know where to get the petrol tank mounting rubbers for the 500T. Thank you
Robert: Do you have the pa…
Previously michael_sulliva…
Previously michael_sullivan wrote:
Robert: Do you have the part numbers?
I will do a local search if you can provide the numbers.
Thank you Mike. I have looked my singles parts list and cannot find the item. Can anyone help with a part number please.
Robert
Re the rubber mounts for t…
Re the rubber mounts for the 500T.
As I am unable to get these items I decided to see what was available to allow me to make ones.
I purchased two classic mini (car) exhaust mountings they have a bonded washer with a threaded bolt on each side. I put a small amount of heat on one metal washer and off the washer etc comes.
I then drilled a suitable sized hole in the rubber (using a vice to hold the other end of the washer etc) and continued drilling through the metal washer. Then with a slim power sander I sanded the rubber washer to the size required to fit the tank.
The tank is now back on. The only small fault is maybe the rubber mounting is about 1/4 inch short.
I find the mini engine sta…
I find the mini engine stay rubbers are really useful too!
