hello , the plug connectors on the wiring loom that connect
the light switch and the ign. switch are shorting out do to
old age. the noc spares are all out of stock on the wiring
loom for the electra, is there another source available to
purchase the wiring loom, also can you buy just the plug
end connectors seperatley and connect them into the existing
loom. thanks a bunch todd stewart
Hi Todd, last year I…
O.K -thanks for the great…
O.K -thanks for the great info - it all helps when your
restoring these older bikes - todd stewart
The wiring for the Electra &…
The wiring for the Electra & Navigator are similar, with the exeption that original Navigator harnesses had a resistor wire in circuit to control charging. Modern harnesses do not allow for this & assume you will be running 12v with a regulator/rectifier and a two wire output from the alternator. If your alternatotor has 3 wires still, join orange & green together to make one wire & the white wire forms the 2nd one. Al Osborn (or I) will be able to help adapt a new Navigator harness for use on an Electra.
Hi Todd, last year I purchased a Navigator wiring harness from an ebay trader called 5*fleamarket who specialises in manufacturing classic bike wiring harnesses and it has proved reliable although I had to re-solder a couple of bullet connectors. I have just checked and he is still advertising them but doesn't list one for an Electra but if you contact him via ebay he might be able to help - sadly I cant find his phone number. Alternatively our electrical expert Al Osborn sells wiring harness kits with all the correct coloured wires and connectors so you can make your own up - particularly useful if you are planning on using a modern regulator / rectifier and including a capacitor. His website www.aoservices.co.uk has lots of advice and his phone number - its often worth a chat to understand what solution you want to pursue. Good luck! Nick
