Hi All
I have justpurchased a 1949 ES2 and rather than trying to ask the previous owner, but one ,my question I thought I would see ifanyone here has the answer. Although a 1949 model it has positive earth electrics,whether by accident or intention I don't know. My question is : Would the original wiring diagram, which is for negative earth still hold good?.
Ed
Previously terence_terrell…
Many Thanks Al. My concern…
Many Thanks Al.
My concern was with the magneto.With a positive earth ,changed in error at some time in the past, would the magneto somehow be in reverse.ie. the spark from the plug body to the central electrode and back to the magneto through the hightension lead?
Terence
It matters not a jot!Mag a…
It matters not a jot!Mag and dynamo run indepenantly and polarity does not make any difference.
OK Thanks Boo!. I must adm…
OK Thanks Boo!.
I must admit I Don't understand how two systems can use the frame as an earth,onenegative and one positive and operate at the same time. I'm used to coil ignition and was expecting to get 40,000 volts through the saddle! Umm.
Best Regards
Terence
Previously terence_terrell wrote:
