Searching for a tacho drive
I am trying to find a tacho drive for my Dominator 99. They are obtainable from Andover or RGM at quite a hefty price. I notice ones on Ebay selling for about £25. They are intended for a vintage Massey Ferguson Tractor.
https://www.ebay.co.uk/itm/276137058014?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160811114145%26meid%3D092a64667a8744d191b36466ae5fcebe%26pid%3D100667%26rk%3D2%26rkt%3D8%26sd%3D395811137353%26itm%3D276137058014%26pmt%3D1%26noa%3D1%26pg%3D2351460&_trksid=p2351460.c100667.m2042
Has anyone tried one of these? Do they work on a Norton? Alternatively does anyone have a good second hand one for sale?
Of course these are available in different ratios and directions of turn. Normally you want a 2:1 reduction to go with a 4:1 clockwise rev counter.
Check carefully the Massey one is correct.
Speedograph Richfield list all sorts of tacho gearboxes.
In reply to by gordon_johnston
Thanks Gordon. I will investigate Speedograph Richfield
Have you thought about using a Triumph gearbox, they are 2:1.  I've used them on several bikes.  Cheap if you shop around but might need some work, they are fixed in place by a left-hand thread on the Triumph,  needs to be right-hand if fitted to the timing cover.
Using one on my Navigator, see photo.
I'm also using a 4:1 ACW (I think) Indian rev-counter head, what a load of rubbish.  Accurate at 30 - 40 mph in top gear, miles out everywhere else.  Not really surprised at less than £20! The cable is Triumph T140.
In reply to by john_crocker
Thanks John. I have already bought an Indian revcounter. I shall discover how useless it is when I get a drive box! My Dommie timing case requires a tacho drive that fits with two small screws so I don't think the type you have fitted to your navigator will work.
