Engine and frame numbers
Hi everyone can someone please tell me where to find the engine and frame numbers on my 1964 Norton navigator
Thanks Mike
Engine number should be stamped on the LH crank-case, just below the barrel join.
Frame number is stamped on the RH frame member, on the spar that the rear footrest bolts onto.
Birmingham bikes - Large stamps on engine, smaller (hence deeper) on frame in one of two positions on the r/hand side:
frame no
On London (Plumstead) built bikes - the fame stampings are larger (hence shallower) and only appeared in one place:
frame no late
Electras (only built in London) had their own numbering system - see previous reply. Jubilees & Navigators followed the Norton numbering system.
Its because of this, the NOC cannot help with Electra numbering system enquiries (for DVLA, for example) as the AJS & Matchless OC has retained the factory records.
Some examples attached of the 3 variants. Enjoy.
