Green spot tachometer and speedo
Can anyone please give me the part number for the correct bulbs (I believe them to be 12v 2w), that should be fitted to the bulb holders for the speedo and tacho. I recently purchased a pair from our NOC shop, part no. 281; but they have too small a bayonet. although the correct specs.
Many thanks,
Gary
is it this one?
https://andover-norton.co.uk/en/shop-details/20413/speedo-tacho-bulb-12v-2-2w-l643
Good morning Tony,
Thank you, yes I think those bulbs could be the correct ones. I purchased a couple of 281's off the NOC shop and although the volt and wattage was ok, the bayonet fitment diameter was too small in diameter. Those bulbs look like the correct ones, available on ebay if my local ,parts shop has no stock.
Many thanks.
https://www.ebay.co.uk/itm/294765607219?hash=item44a1663933:g:TpIAAOSwEHpdEyVl&amdata=enc%3AAQAHAAAA4JdG3o1OvAzlFHYBfrfOBqa6IgUMDfw9U%2BUcfwCoKuIhA%2FD9gVyZ7cBFeXmDao7V6ncIH8FoczRaRXVGE%2FuSXeBa66enl9Y42u9GEOBb7ypA4YwWzqMc6ZuyO5N6LMdt%2BfOoBWruU5HqDJvgGm395WqwhpppEpYGuGJReE2BGy3lN3dVjJTTmmFifwY5ng3WKZXyH3l0C0j%2Fd4bp2DVNTTR3Yo05viuH%2FqikHZ5DHW3GuQwu6URE47%2BE9eA%2BWfR3elYFWD5F5U6SvFIBvhq8WeJ%2BJOJ08GznSVAwX0AOxukh%7Ctkp%3ABk9SR_DM6aXbYQ
